It is currently Tue Jul 22, 2025 2:12 pm
PostPosted: Fri May 12, 2006 7:57 am
I have a commision for an SJ; Koa b/s Carp Spruce top IRW fb and bridge, Mahogany neck with IRW center laminate and back veneer, Koa top veneer. The customer really wants dark body bindings but wants lighter fb binding to contrast to the FB.
I have never bound a fb with different wood than the body bindings before, but I think I may have worked out a combo that will work. Let me know what you think.
body: Koa/Spruce with IRW binding
fretboard: IRW with Koa binding
Well what do you think will this work?
PostPosted: Fri May 12, 2006 8:10 am
Great combination
using Koa binding with IRW fretboard and reverse on the body
Go for it
PostPosted: Fri May 12, 2006 8:36 am
Michael
I think that will be just beautiful
PostPosted: Fri May 12, 2006 9:12 am
Sounds great to my ears Michael, balanced would be the right word!
PostPosted: Fri May 12, 2006 9:18 am
When in doubt, match the body bindings to the neck laminate and the fb to the b/s...can't go wrong there as far as complementing each other
PostPosted: Fri May 12, 2006 9:19 am
Before I read your idea, I was thinking the same combo there Michael.
I think that it should look very nice indeed.
PostPosted: Fri May 12, 2006 9:22 am
I would see if the customer would do something like this. This is a
Brazilian board/headplate with brazilian binding separated by a 10/10/10
maple/black/maple. It gives the contrast and stuff ties the whole thing
together...
PostPosted: Fri May 12, 2006 9:29 am
I really love your headstock design John.
I have been sitting down sketching designs and can't come up with anything I like.
PostPosted: Fri May 12, 2006 10:12 am
Sounds nice....but so would a nice orange cocobolo binding, with perhaps a WBW purfling thrown in between on the whole thing?
I did a Taz Blackwood OM with that combination and it looks great.
But the more I think about it, I like the switch-up of binding the koa with the EIR, and the EIR with Koa. That sounds really cool.
Don Williams38849.8006597222
PostPosted: Fri May 12, 2006 2:55 pm
Client does not like the coffee and cream color you can get with BRW pluse the cost of the bindings. the client originally wanted ebony body binding and curly maple fb binding. but I talked hem out of that thinking the curly maple would dominate and not tie in to anything. I will also try to talk him into IRW peghead veneer on top[ so that I can continue the Koa binding around the peghead and fb. But he is pretty set on Koa top veneer
PostPosted: Fri May 12, 2006 7:47 pm
Matching the B&S and fingerboard binding would look great and makes an arguable design statement, Koa it is.
PostPosted: Fri May 12, 2006 10:29 pm
You did right in talking him out of the flamed maple....it would have overwhelmed everything else, and would have looked out of place.
PostPosted: Sat May 13, 2006 12:19 am
I think it sounds real good with matching peghead.
PostPosted: Sat May 13, 2006 1:17 pm
Have y'all found that relatively light-colored wood bindings, such as koa (or maple even moreso), look good on a fretboard after a few years? Do they get grimey looking? I don't have personal experience with this, but I would think it could be a problem...
Aside from that possible concern, I think your idea sounds great, Michael.Todd Rose38850.9295023148
Todd Rose
Ithaca, NY
PostPosted: Sat May 13, 2006 6:38 pm
Maple bindings can look grungey, but I've taken to simply painting on (tiny artists brush) shellac on the exposed edge. Works a charm. Besides, easy enough to clean up (single-edged razor blad) and re-finish. Takes all of 5 minutes.
